Hi community.
I heavily use shell scripts with BTT though, I'm not sure what exactly are the differences between them:
- Execute Shell Script / Task
- Execute Terminal Command (Async / Sync)
Yes, it's obvious that Execute Shell Script / Task is capable of specifying invoking environment like Launch Path, Parameters and etc.
If you are to invoke node, python or ruby - Execute Shell Script / Task is more preferable, I suppose. Or if you want to invoke script on the fly and check the result.
However, in the situation that you simply invoke a script or executing one-liner in sh / bash... I mean, just simple as:
~/bin/foo.sh | bar
# 'foo.sh' has shebang, bar is bin in the PATH that BTT can recognize.
In such case, what's the difference there?
Hi @Andreas_Hegenberg , I assume you're the only one who can tell what the exact difference is, since this is the internal implementation things. When you have a time, could you have a post please?
Thanks.
