When using ChatGPT from the floating text selection menu, all works as expected until the response is returned. Then, somehow, Alfred is getting invoked and receives the streamed text. I can't figure out how to stop this happening.. :-/
Pressing the escape key (you can her it the video) briefly stops Alfred, but not for long. All a bit odd..
what shortcut are you using to show alfred?
When using the streaming response BTT needs to send cmd+v multiple times to paste the response parts
Thanks for the super quick reply. I am using command-Space....
I switched to option-command-space briefly to try that, no change in behaviour.
