Web View not working for local device
Hi. The Web View action is not working with a local electronic device: a home cinema processor with local address https://192.168.1.140:10443/. The page loads in Safari and chrome without warnings after including its certifidate in Keychain.
Any ideas?
I have found a workaround setting up a local reverse proxy (Nginx) to forward requests to the HTTPS server and serve them over plain HTTP. WKWebView can load http://localhost without SSL errors.
Example Nginx config:
nginx
CopyEdit
server {
    listen 8080;
    location / {
        proxy_pass https://192.168.1.140:10443;
        proxy_ssl_verify off;
Then use http://localhost:8080 in your BTT WebView action.
