i see many windows opened with title "Better Touch Tool Java Script Runner" and Item script UUID. Most of windows has the same ID, but I see also a few others. I have enabled Programming option in Safari.
- Type of Mac: MacBook Air 2020 M1
- macOS version: Sequoia 15.3.2
- BetterTouchTool version: 15.271
It shows always when I double tap trackpad to mark (select) words on screen.
most likely you accidentally enabled "Automatically Show Web Inspector for JSContexts" in Safari's Developer menu.
I don't see such option
Could you point the place of that (currently I have Polish language in system and it's hard to find english counterpart)?
Thanks
unfortunately I'm on macOS 15.4 beta and Apple removed that option there, however it should be somewhere here:
I found it, thanks.
It had to be incidentally enabled.
Thanks again
