I am not sure if this is a bug or if I failed when setting up the weather widget, however, it seems that the weather widget is not refreshing in the touch bar. The weather widget in the MacOS notification center shows the current weather, and is refreshing every hour. The weather widget in the touch bar is unfortunately not doing so. This morning it was showing the same weather results as it was last night, even the day in the weather widget was yesterday's and not today's. If someone knows how to fix this it would be really appreciated.
