Hi, after update BTT 2.697
Whether widget can't show anything..
It's same with GCC's whether widget
Make sure to allow BTT in your firewall. Also if you use the "auto location" feature, make sure BTT has the correct permissions in System Preferences => Security & Privacy => Privacy => Location Services
thank you so much !!!!!!
