When I enable the weather widget + forecast, it only shows the weather of the last day, not multiple days.
Affected input device
Macbook Pro Touch Bar
- Type of Mac:
Macbook Pro 15" 2018
- macOS version:
10.13.6
- BetterTouchTool version:
3.093 (1200)
For maximum customizability the weather widget always only shows one day. If you want multiple you need to add it multiple times and select different days in the settings.
ok thanks for a super quick reply
And what is the unit of the wind speed. Kmph? Beaufort? Can I change it to knots and maybe show the maximum?
Edit: oh found it, it must be Beaufort. Can it be knots?
