I use an email/web app client called Wavebox. It just updated to a new version, version 10. Since that upgrade, I cannot use Snap Areas with the Wavebox window, and have found that its window does not respond to being dragged to a screen edge, nor can I double-click on its titlebar to maximise it.
Regarding Snap Areas, I have tried the following:
- Select the Wavebox 10 window
- BTT -> Snap Areas -> Create New Snap Area Using Current Window as Template
- Save the snap area
- Now try dragging the Wavebox 10 window. The Snap Area does not appear. This is the same regardless of whether I filter the Snap Area to Wavebox.app specifically, or leave it unfiltered for all apps. The Snap Area just doesn't appear while I'm dragging the Wavebox window, as if BTT doesn't even detect I'm dragging a window.
Wavebox 10 is a Chromium-based browser-style app. Previous versions of Wavebox were using a framework called Electron, not Chromium. I therefore think it's the change to Chromium that has caused these issues.
I performed the same tests with the latest version of Google Chrome, and found that Chrome does respond to Snap Areas, and to screen-edge snapping. But it does not respond to double-clicking its window to maximise.
I remember some bugs related to Chrome in BTT from a few years ago, and therefore wonder if there are general issues with Chrome/Chromium in BTT, and that specific fixes have been added for Chrome, but these don't work for other Chromium apps eg Wavebox 10?
Mouse/Trackpad
- Google Chrome correctly displaying Snap Areas as I drag it
- Configured Snap Area meant for Wavebox
- Wavebox not displaying any Snap Area as I drag it
- Wavebox not responding to screen-edge drag for maximise
- Another window (Activity Monitor) responding to both screen-edge maximise, and showing Snap Areas
- Type of Mac: Hackintosh emulating iMacPro 1.1. Intel Xeon X5670 CPU, 48GB RAM, AMD RX Vega 64 8GB GPU.
- macOS version: 10.14.6
- BetterTouchTool version: 3.220 (1397) alpha
Let me know if debug logs would be of help.
Here's a link to download a free trial of Wavebox 10 for testing: https://wavebox.io/
