A keyboard shortcut involving "Volume Up" key no longer works. Interestingly, a shortcut involving "Volume Down" does work still.
Affected input device
Keyboard (MBP)
- Type of Mac: MacBook Pro (Apple M2 Max)
- macOS version: Version 26.0 Beta (25A5279m)
- BetterTouchTool version: 5.468
Additional information
I have "SHIFT+Volume Down" increase the volume and "SHIFT+Volume Up" decrease the volume. Each of those shortcuts run two actions. The first is an Apple Script such as:
set volume output volume ((output volume of (get volume settings)) + 6.25) -- Increase by 10%
Where the amount is either +/- depending on what's intended. The second action is a Terminal command that plays the system's volume change sound such as:
afplay "/System/Library/LoginPlugins/BezelServices.loginPlugin/Contents/Resources/volume.aiff"
If I make it so the HUD Overlay is displayed when triggered, I see the "SHIFT+Volume Down" action working but not the "SHIFT+Volume Up".
This has worked previously.
