BTT 5.800 and macOS 15.7.2
If I select a visual separator that has already been configured, the colors are not updated.
It seems that the colors are frozen to the last colors modification.
Screenshots of two visual separators:
Is this in some specific trigger category or subgroup? (It seems to work fine here in a few separators I tested)
I use visual separators everywhere where I have triggers of different classes, they are very useful for visually organizing BTT configurations.
99% of the visual separators I use have a blue background and a white font, with the following combination already shown before:
I only use different colors in the "For All Apps" category, in the sections of:
Did you find some issue? Could you replicate that?
unfortunately not yet, it works fine on all machines I tested it on (even 15.7.2).
I can replicate the issue doing the following steps:
1- copy one visual indicator from any section of the group "For All Apps"
2- paste it in another section of the group "For All Apps"
3- change the text and the 4 colors of the pasted visual indicator to 4 colors never used
4- save and restart BTT
5- select any visual indicator in any section and the four shown colors will be the never used
As example I have done the 3 first steps with these combination:
Then, any visual separator I select is showing this combination:
Could you replicate the issue doing the same 5 steps?
Ah, I think I can reproduce the incorrect display of the selected colors - however you can still change them, right?
Yes, I can change background and text color without any problem or limitation.
It is only a visual issue: the color of the visual separator is not matching the color of the configuration panel, which is a little bit confusing.
Fixed in BTT 5.803
