Visual inconsistency when using "Differentiate left/right modifier keys"
And you are right, left/right ctrl + letter is a fantastic addition to set up shortcuts.
Very natural for the left hand, thumb and index finger.
I explained to you how to turn caps lock to right control and you showed me how to use both control keys together. We are a good team :wink:
Agreed - although I manipulate my hand differently because my eager pinky finger feels left out otherwise :joy:. (I've also swapped fn and left control to match with the layout of a logitech bluetooth keyboard I use frequently - that was why I still had the hidutil hack in my head earlier).
The display issue should be fixed in 3.977 alpha (uploading now)
That looks good
And that's still wrong, of course, but probably can't be changed.
Ok for me :slightly_smiling_face:
Ah, and thanks, Andreas!
I've tried updating a few times now via the "Check for Alpha Version Updates" but it keeps telling me there's none available? I've attempted from both 3.971 and 3.952 with the same result :thinking:.
download alpha versions here
https://folivora.ai/releases/
Awesome, got it now and can confirm the left/right modifiers in combination look perfect. Thanks again!
Ah sorry, the alpha update check should now work again.
