Hallo Andreas,
Is it possible to add a floating menu slider in vertical orientation as well ?
I want to use 8 of them as a kind of channel volume mixer slider.
The horizontal ones are for panning left/right…
Thx Christian
Hallo Andreas,
Thx Christian
Good idea, I think I can integrate a library like GitHub - buh/CompactSlider: CompactSlider is a SwiftUI control for macOS, iOS, watchOS and visionOS.
Very nice! Next on the list would be knobs ![]()
Hallo @Andreas_Hegenberg,
a suggestion:
when using BTT Mobile finger "touch" the slider could be improved to allow a "touch" also in those areas as per below screen, this would then be similar when "clicking" with a mouse there.
I have used a mouse on the iPad and the slider works as expected. A mouse click in those areas is moving the slider...
Thx,
Christian
