I've been struggling with a problem for a while now:
In all applications mouse wheel up/down + CMD is configured to execute keystrokes UP and DOWN to move the selection in e.g. Finder or even Bettertouchtool… guess what.. up and down ![]()
In some applications mouse wheel up/down + CMD is remapped to different keystroke just because some applications use other keystrokes to move a selection up and down (e.g. Thunderbird uses b (backwards) and f (forwards)).
Now at least since macOS 14 this does not override the standard system behaviour of the mouse wheel which is of cause to scroll the window up and down. So what I end up seeing is that windows and selection are being scrolled up and down at the same time when using these mappings.
I would expect Bettertouchtool to override the standard system behaviour. Can this somehow be fixed, forced, enabled?
Affected input device: Normal Mouse
- Type of Mac: Mac Pro 2019, Mac Mini 2018, Macbook Pro 2015, Macbook Air 2020, Mac Pro 2023
- macOS version: 14
- BetterTouchTool version: 5.622
