Using my magic mouse, vertical scroll triggers single left click/tap. This is really annoying. I'm using Magic Mouse 2 on macbook pro retina 15" mid 2014 running Catalina 10.15.7 (19H524). Restarted system, no go. Restarted BTT a couple of times, still the same thing. Turned both bluetooth and mouse on/off, didn't resolve the issue. BTT Version: 3.561 (1701)
- Type of Mac:
- macOS version:
