When disconnecting from a wifi network the variable The currently connected wifi is: in BTT does not change.
Automations that rely on the disconnection work fine. Therefore BTT seems to recognize the disconnect fine, but automations that trigger when connecting to a certain wifi network do not trigger when the previous connected wifi network was the same.
The variable The currently connected wifi is: does get updated once i connect to different network than the previous one.
Therefore one automation triggers (killing DisplayLink Manager when leaving the office wifi). However the automation to start the same programm when reentering the wifi network does not trigger if i did not connect to a different network in between.
Here you can see that i am not connected to a Wifi but it still says "The currently connected wifi is: C(...)
I just reproduced a similar issue on version 4.272. Seems like the variable didn't get updated when my laptop connected from my iPhone hotspot to my home wi-fi. Here's the details:
I was connected to my iPhone Hotspot, away from home.
I closed my laptop's lid and packed it for travel.
Everything with my CAG worked well up to that point.
30mins later when I opened up my laptop at home, it connected to my wi-fi.
My CAG was off and BTT's variable Connected Wifi was set with my iPhone Hotspot's SSID.
When I manually reconnected to that wi-fi, everything got set back correctly. BetterTouchToolDebug.zip (1.9 MB)
