Hello community,
is it possible to use two mouses with their own cursor positions? For example when you move mouse #1 the mouse pointer moves from where you left its last position. When you move mouse #2 the mouse cursor moves from where you left it the last time before you switch back to mouse #1 again.
I hope you understand what I mean!
Is it possible to set it up with BTT?
Thanks for your support!
interesting idea, but it is currently not possible- at least not with BTT.
Hello Andreas, thanks for your reply!
There are tasks where it’s quite handy to have this functionality. Especially when one mouse is used for triggering actions while the other for general mouse activities.
I’ll check whether it’s doable, I’m not sure right now whether I can get the mouse type that last moved the mouse, but maybe it’s possible
Thanks Andreas for taking it into consideration!
