For a while, I have been trying to use the "Delete" button to go 1 folder back in Finder and "Return" button to open the folder/file. This has been a feature of Windows File Explorer forever and wanted to replicate this behavior in MacOS.
Whenever I tried implementing this, it always resulted in breaking something or the other like when trying to rename a file or when using spotlight.
Finally I figured out and wanted to post this so others may find it useful.
Test it out. With this method, the triggers won't work on desktop or when renaming or anywhere else. Only when you are in a Finder window and navigating.
good job! thanks. I had encountered the same issues so this awesome. Implementation seems to be working great with no problems when renaming or using spotlight/Alfred etc
actually i did run into some issues-IIRC when renaming files the delete would not delete but instead moved back/up in the folder structure. This was one of the couple issues that I had encountered before. Was able to fix it and get iit working by adding a couple new triggers for the delete key and adding some advanced conditions to them using the condition element_focused contains (and the one not containing) AXtextfield. Added the 2 desired actions, the default delete and then cmd up or cmd [ depending yourr preference of back or folder up
Can you provide / update this as an exported preset? I am unable to "paste" it back into BTT, and apparently using presets is the proper way of doing this -- more info here: Presets · GitBook
Thanks! I didn't know about conditional activation groups
I mapped these to key sequences (double tapping Enter anf Shift respectively), and it works great!
@Andreas_Hegenberg Just bought a BTT license for Black Friday, thank you!
Is it possible to achieve this without a conditional group and just using the Advanced Conditions on the keyboard shortcut? Could you provide an example if you're available?
yah i encountered same issue thus the changes i made in order to remedy problem when in textfield ie renaming a file etc it would not delete letters/function properly until i made my changes.
here is an exported preset of what i currently use. works fine when using delete in textfield or other app like raycast etc or renaming something in finder but still goes back to last or up a leve/directory in finder and enter opens folders etc.
