Using BTT with contexts alt+tab?
Can't seem to figure out how to get contexts to pick up the keystrokes coming from BTT
I've tried apple script, background and blocked
Tried the embedded keystroke option
No luck. I can get option down to engage and option up to engage when I remove my finger but I can't get the tab to be recognized, unfortunately. While my fingers are still touching I can click tab and contexts will pop up but not using any command from within BTT
Edit:
I got it working somewhat, I think I had not converted one of the named commands to an apple script blocking one.
tiptap right:
script for option down
script for keystroke tab
upon release script for option up
tiptap left:
script for keystroke tab using shift down
This method seems to be slow between taps but what I found is that after I do my 2 finger down tip tap right, I can switch to my regular tip tap single finger down which is a simpler alt tab without a script so that seems to be more responsive and works in both directions.
I think the apple script is needed for contexts to recognize the keystrokes initially
Hey,
what do you mean by contexts?
Best,
Andreas
It's a software for mac
I'll have a look!
It's still not fixed. Any clean solution for Contexts to pick up the keystrokes by BTT?
I ended up scripting the commands
If you happened on this like I did trying to get the AltTab app behavior to work, here's what I did.
For 3 Finger Tap, add action Run Apple Script (blocking) and put this in the text box:
key down {option}
key code 48
delay .01
key up {option}
end tell
Now when I 3 finger tap it goes to the previous window. Had issues trying to use the native option.
Hope this helps!
By the way, have you tried BTT's window switcher (predefined action "Show Window Switcher For All Apps")? That one can better be integrated with BTT's gestures/triggers.
I'd be happy to add features needed to make this work for you in case it is missing something.
