Ive just migrated to new MacBook Pro 2018 (HighSierra osx). Ive discovered some strange behavior of BTC.
Overall the TipTap is less responsive then it was on my old MacBook ( 2016 , El Capitan osx), but after a while (possibly after computer sleep) it gets really unresponsive- most of the time you need to make a gesture on a trackpad at least twice, also after a while the two finger swipe from the top stops fully working. The reset of BTC doesn't help the only solution is a reset of the whole system.
One more bug Ive noticed: I use use tap to click, in safari Im using 3 fingers tap to open a link in a new window. Whenever I try to use that gesture computer recognizes both. On my old system it was working as a charm.
Affected input device : MacBook Trackpad
- Type of Mac: MacBook Pro 2018
- macOS version: HighSierra 10.13.6
- BetterTouchTool version: 2.652 ( but the latest none alpha version have the same issues)
