Hi there,
I’m experiencing an issue with certain simple trackpad gestures triggering modifier key behaviour (function / Fn) in Chrome/Firefox.
As I use the Fn key for voice dictation (using Willow Voice), this disrupts my workflow and is a general annoyance. No other gestures trigger this behaviour, from my tests.
Observe the behaviour below.
First, I show my BTT configuration for these two gestures.
Second, I trigger the two BTT gestures (3 finger swipe left/right) — both cause voice dictation to activate, as if the Fn key was pressed down.
Third, I trigger the actual raw, underlying keyboard shortcuts (Option + Command + ← for Select Previous Tab; Option + Command + → for Select Next Tab). These work as intended, and does not trigger modifying key behaviour.
Please let me know if you need additional information, e.g. debug logs.
Would love to see this fixed!
- Type of Mac: MacBook Pro 14” — 2021 (MacBookPro18,3 / MKGT3B/A)
- macOS version: 15.7.4
- BetterTouchTool version: 6.477
