unaspected click for every key sequence
Hello everyone, when I type the keystrokes to activate an action, the noise occurs at each key in the sequence, what problem do I have?
key sequences can not block the pressed keys from reaching the active app by design, thus if the active app handles these keys and decides to play some sound in response there is not much you can do (apart from combining it with some start trigger that starts blocking keyboard)
please, where Can I find out your "start blocking keyboard"?
it is in the list of actions, but the setup really depends on what you need. How would you like to start such a blocking “key sequence input mode”? using a keyboard shortcut?
I suppose so; please tell me how to do it. Attached is a screen of how I configure my shortcuts
Can you type all that in less than 0.3 seconds?
Maybe it's better to use Control+C as a shortcut that does what it's supposed to do, and then blocks the keyboard.
Then you type G, D, R, and the R unblocks the keyboard when you release it.
I don't know ... if you explain more clearly what you're trying to achieve, people might be able to help you bettter :slight_smile:
