Description
When "Restore old size & position after double clicking again" under Extras is enabled and "Restore old window size if window is dragged away again" under Customizations is disabled, the expected behavior is that double clicking again should restore the window size (and dragging away does not). However, double clicking again does not restore the window size. I have to also enable "dragging away to restore" in order for the "double clicking again to restore" to function.
All clicking devices I have (mouse and MacBook trackpad)
- Type of Mac: MacBook Pro 16inch
- macOS version: 10.15.5
- BetterTouchTool version: 1.9.3
Like mentioned above, the only workaround is to enable both "doubling clicking again to restore" and "dragging away to restore". However, what I want is to disable "dragging away to restore" while keeping "double clicking again to restore" enabled.
