I'm unable to select a large paragraph of text or drag sliding elements inside a webview. Is there a known limitation or is there something I can do to fix this?
what kind of webview, version of BTT & version of macOS?
The issue occurs regardless of whether it's 'Floating Webview / HTML menu' or 'Web View / HTML item' in a floating menu, and whichever URL I load (without any scripts added).
BTT 4.361
Sonoma 14.2 (23C64) – using a trackpad to click and drag
