At random times during cursor movement (I have several trackpad gestures configured in BetterTouchTool for a specific app) using trackpad the cursor and keyboard input freezes. When the freeze stops it continues to work as normal. The more trackpad is used the more often freezes happens. Exiting BetterTouchTool helps. Switching the apps also might trigger freeze. It looks like attempt to analyze trackpad movements creates huge CPU load for a moment and that looks like a freeze. Wasn't happening before and I haven't upgraded BetterTouchTool. Looks like it's a compatibility issue with 10.13.5. Happens instantly on BetterTouchTool 2.530 version, when trial window opens.
Trackpad (external Magic TrackPad connected over Bluetooth).
- Type of Mac: Mid 2012 MacBook Pro Retina
- macOS version: 10.13.5
- BetterTouchTool version: 2.425 (free), 2.530 (on trial)
I have the latest free version of BetterTouchTool installed.
