Since 'saved_mouse_position' variable that gets crated by a corresponding BTT action is a list of two numbers, is it possible to get it as a properly non-typed Javascript data type instead of parsing it as a string?
Thanks, but this is a bit backward since I'll also have to change it back to a string since I want to feed the result to a move mouse action, which afaik from Using Java Script (not JXA) · GitBook requires a string for mouse position
That's all for passing values within the app
BTT uses the system point serialization format because this is used in various places in BTT (and because this stuff was created long before BTT was scriptable :-)). Maybe in the future I can add separate x and y number variables
