Two UI bugs related to the "Groups & Top Level Triggers" search
  1. After search in the "Groups & Top Level Triggers", the icons on the bottom right of the panel are still visible:
  2. After search the result/action seems to be selected (check above screenshot), but in reality it is not and the two right panels are showing the config for the trigger which was selected before the search which may lead to confusion and unintended changes.
sounds like there is an unhandled exception, I'll have a look.
Weirdly I also couldn't reproduce your search related crash, but maybe this is similar.
I've just checked and the number 1 does not happen if no dark mode:
This is fixed in Version: 5.248 (2025030304) and possible few version before that one.
