Issue #1: I have an automation that hides the BTT icon and all the icons on its left whenever I right-click on the notch area. The problem is that after this if I right-click anywhere else it keeps triggering the automation infinitely. So I have to left-click somewhere before being able to use right-click normally again after using the automation.
Issue #2: The mini status item widget is not very responsive. It takes quite long for it to refresh when something changes. Moreover, icons occasionally freeze and/or are not displayed properly. (Edit: this affects the displayed time too)
I'm using:
MacBook pro 14' with M1 pro chip
BTT 3.744
MacOS Monterey 12.2.1
