Hey Andreas, did you manage to post the instructions mentioned here? If so, where can I find them?
I posted an example here:
I quickly made a VERY basic one:
circular-sub.bttpreset (103.4 KB)
Basically the trick is to place a larger floating menu over a smaller one by using the positioning options:
Perfect! ![]()
Back in the days of Logitech Mouseware, you could create a radial (but square) popup menu, with eight configurable icons. I can't find any picture of it, but I did find a picture of the successor Logitech SetPoint, with the option "Windows: Show custom menu". I'm not sure if that is what I'm looking for though, or if that was a normal context menu (with custom items).
Anyway, I had it on middle-click, and it looked something like this:
| App menu | Maximize | Close | |
| Alt+Tab | On top | ||
| Start menu | Minimize | Desktop |
I clicked and held the middle button, and moved my trackball in the direction I wanted. The pointer couldn't leave the popup menu, so I didn't have to care about hitting the icon, only about the direction. The action was executed on mouse button release. If I wanted to cancel, I released it on the middle icon.
It made it super fast. Even faster than keyboard shortcuts.
Would it be possible to adapt this radial menu to something like that?
locking the mouse cursor into the menu should be easy, I'll check
or maybe an option like "trigger last hovered item" on menu close
