Hello,
Can't quite figure out what the specific problem is here and if it's something unique to my set up or not. Basically, I noticed every once in a while when I use a system launche like spotlight or raycast, the enter key doesn't trigger the proper action and I either have to manually click on the highlighted action or sometimes shift+enter works. I've been able to narrow it down to being an issue primarily when Finder is the active application and BTT is open. I made a quick video to demonstrate what I mean.
Any help would be appreciated, thanks in advance!
