Triggers will not move to designated preset; presetbundle folders are empty
I somehow created additional presets and I wish to consolidate.
I named the additional 3 presets as extra 1, extra 2, and extra 3.
I went through all off my triggers, selected them, and chose Presets > Move Selected Triggers To Preset > Default
When I deleted the extra presets, the triggers started disappearing. So, I restored through backup.
I thought I might manually move them. I opened the folders via the presets popup, but all of the PresetBundles folders were empty.
Where are the triggers and how do I move them all to the Default preset?
  • Type of Mac: iMac 2017
  • macOS version: Monterey 12.0.1
  • BetterTouchTool version: 3.616
I have also noticed the the preset data folders inside ~/Library/Application Support/BetterTouchTool/PresetBundles are all empty. Is this normal behaviour?
yes by default they are empty, for floating menus sometimes images will be saved there. In general you can move files there that you want to be exported with your presets.
