Triggering events with multiple clicks (double clicks or as many as you like)
Ok so I know I am going a little over board .. but I took this idea form movingimage from the post found here and modified it to work with as many clicks as you would like.
It will execute a different trigger for each click as you go..
I have a screen setup that has 8 different snap areas and this allows me to rotate my active window through all of them by continuing to push the same button/keystroke. It does have a timeout of one second.. so if you can not click faster than one second per click you can adjust the time.
steps
  1. Add the desired triggers to the "Named and other Triggers" section of BTT
  2. Set up a Button/Keystroke and assign it to "Run Apple Script (async in background)" and copy the below script in
  3. adjust the script for how many clicks you would like in the clickCheck section. I put in ten but I only use eight. you just have to move the line indicated with a
    "-- Move me to the amount of clicks you have"
  4. Rename the trigger events to match the ones you set up on the "Automations & Named & Other Triggers" page in step 1
  5. Click the "Complie / Test" button and then select save.
  6. Click/Push/Keystroke your key or button that you set up and watch the magic happen.
Note*** if you use this multiple times for other triggers you may want to change the global variables as they would conflict with the other.
--#	Written by doctorquad July 2020
--#	This script will do exactly what you tell it to ... The common problem in all errors is YOU
--#	Author takes no responsibility to how when or where you use this script... Note the above comment.
global currentCount
global lastRunTime
global timeDelay
--Set this to the time delay in secconds that you would like
set timeDelay to 1
checkDuration()
--Check to see if it has been more then 3 secconds
on checkDuration()
	try
		-- Set the duration based on the global variable that was set last time this ran so we know how long it has been.
		set duration to (current date) - lastRunTime
		-- If it has been less then the set timeDelay run the clickCheck. if not reset the count and run the clickCheck
		if duration ≤ timeDelay then
			--Run the clickCheck with the current count of clicks
			clickCheck(currentCount)
		else
			--We missed the timedelay window so reset the count and run the clickCheck
			resetCount()
		end if
	on error
		-- If the script has not ran we get an error because the variables are not set..  we need to set the variables then run the clickCheck
		set duration to "FirstAttempt"
		resetCount()
	end try
	log "Duration from last click " & duration
end checkDuration
-- Update the last time this script was ran
on updateRunTime()
	try
		set lastRunTime to current date
	end try
end updateRunTime
-- Reset the count to 0
on resetCount()
	try
		set currentCount to 0
	end try
end resetCount
-- Incrament the count or set it to 0 in error
on increment()
	try
		log "incrementCount " & currentCount & "."
		-- Increment the count by one
		set currentCount to currentCount + 1
	on error
	end try
end increment
--This is what does all the work depending on how many times you clicked will run through the clicks
on clickCheck(clicks)
	try
		log "clickCheck " & clicks
		if (clicks = 0) then
				trigger_named "RaiseWindow"
				--change this to be your 1st trigger name
				trigger_named "MoveMain"
			end tell
		else if (clicks = 1) then
				--change this to be your 2nd trigger name
				trigger_named "MoveBigMain"
			end tell
		else if (clicks = 2) then
				--change this to be your 3rd trigger name
				trigger_named "MoveBottomLeft"
			end tell
		else if (clicks = 3) then
				--change this to be your 4th trigger name
				trigger_named "MoveTopLeft"
			end tell
		else if (clicks = 4) then
				--change this to be your 5th trigger name
				trigger_named "MoveTopMain"
			end tell
		else if (clicks = 5) then
				--change this to be your 6th trigger name
				trigger_named "MoveTopRight"
			end tell
		else if (clicks = 6) then
				--change this to be your 7th trigger name
				trigger_named "MoveBottomRight"
			end tell
		else if (clicks = 7) then
				--change this to be your 8th trigger name
				--This is where you set the count back to 1 so that it will keep looping.  If you do not have 8 triggers then move these lines to the last one of your set.
				set currentCount to 0 -- Move me to the amount of clicks you have
			end tell
		else if (clicks = 8) then
				--change this to be your 9th trigger name
				trigger_named "tbd"
			end tell
		else if (clicks = 9) then
				--change this to be your 10th trigger name
				trigger_named "tbd"
			end tell
		else
				--change this to be your what trigger you would like the defualt to be.. you will most likly never hit this but you never know.
			end tell
		end if
	on error
			--This is just the trigger that you would like to run if for some reason you get an error .. usually when you run the script for the first time as it has not populated the varables yet.
		end tell
	end try
	--Update the last run variable so that the timeout start over.
	updateRunTime()
	--incrament the count so the next click will go to the next trigger.
	increment()
end clickCheck
awesome! just a tip: you can indent the coding by highlighting it and pressing Command + Shift + C
Yeah I am trying to get the format of the script to look better on the forum I tried your suggestion but it still looks the same
Ok found the "blockquote" button and that seems to have worked .. thanks for the tip.
Not working.
here's my script :face_with_raised_eyebrow:
I tried with only 2 clicks.
global currentCount
global lastRunTime
checkDuration()
on checkDuration()
try
set duration to ( current date ) - lastRunTime
if duration ≤ 1 then
else
resetCount()
end if
on error
resetCount()
end try
end checkDuration
on updateRunTime()
try
end try
end updateRunTime
on resetCount()
try
end try
end resetCount
on increment()
try
on error
end try
end increment
try
trigger_named “split”
end tell
trigger_named “esc”
end tell
else
end tell
end if
on error
end tell
end try
updateRunTime()
increment()
end clickCheck
Wow I am sorry that I did not get back to you on this.. Hopefully this might help others that may have a simmiler issue.
Form my quick clance the script looks good.
I am guessing that you were also able to set up the "Named and other Triggers"?
(in the later Versions of BTT the section that you set these in is called "Automations & Named & Other Triggers" )
One thing that might cuse this to seem like it is not working is that that this will run the triggers specified on whatever window has focus. So if you have it set to a mouse click for instance it might change the "raised" window when you click and not apply the change to the desired window... if you click on the desktop then it deselects the window and it will not really do anything.
I will update the post to have the right name
I also update the script to make it a bit more understandable.
