I have multiple triggers assigned to the same keyboard shortcut, and I then can select which action to execute by pressing their number (1–9) in the list that appears on the screen.
Occasionally, it seems that BTT randomly reorders the list of triggers, which changes their positions and affects which action is executed when I press a number. This behavior appears inconsistent and can disrupt my workflow.
Is there a known cause for this, or a way to prevent BTT from reordering triggers? Any guidance would be greatly appreciated.
Thank you for your time and for maintaining such a fantastic tool !
- Type of Mac: Macbook Air M2
- macOS version: Tahoe 26.3
- BetterTouchTool version: 6.253
are you using the experimental dropbox or icloud sync? that's the only thing I can think of that could cause something like this
ah wait now I understand, you are using the conflict menu that shows when you have multiple same triggers with different actions?
I think there no explicit order is defined, it would be better if you'd use the dedicated "Show Context Menu (New)" action.
Understood.
I will switch my triggers to the context menu action and keep you informed if the problem persists.
Thanks a lot !
I just checked again though, in general the conflict menu should adhere to the order displayed in the UI - maybe for some reason (possibly copy paste or some import issue) the triggers have the same order property? Could you try to select your triggers, copy them and paste them in a text editor? Every trigger should have a distinct order property showing there
The conflict menu does respect the order displayed in the UI.
The issue is that the list of triggers in the UI sometimes gets randomized for no reason, so I have to manually reorder all the triggers in the UI.
Here are text files as requested of a list of triggers that have been randomized for no reason (the OPT 2 triggers in that list are not in the order that they used to be).
problemwithorder.txt (310.0 KB)
