hi, I was curious whether it's possible to make an action that'll invoke haptic engine, so you can attach it to various devices.
I mean:
I'd like to have a trigger which can trigger haptic engine, but it would also be great if some keyboard shortcuts could trigger the haptic engine.
Personally, I would like to use it on a named_trigger, and trigger it via webserver endpoint (for example, to know when the widget has updated asynchronously or similar)
Is that even possible? What do you think about it @Andreas_Hegenberg?
Thanks Adreas!
