I used the trigger context menu function to set shortcut actions for Figma, but after I set it, I found that it could not be triggered, he would only activate the right click menu panel, but would not trigger the function, I carefully checked the operation instructions, my settings are: Copy/Paste as;Copy as SVG
BBT Versions :3.952
System Version:macOS 13.0
