I'm trying to create a Floating WebView on top of all apps, with a large transparent region that should be click-through to get to the apps underneath - anyone know if this is possible?
This can be done with Electron apps, but not sure if it can be done in BTT...
Click through is currently not possible with the floating webview. I'm looking into it though, if I find a way to allow this, I'll add it.
Thanks, I reckoned it wasn't but just wanted to be sure in case there was a workaround.
@Andreas_Hegenberg this had any further development? I'm also looking for it
