Transform & Replace Selection Wtih ChatGPT does't work with "gpt-5" model.
  • Type of Mac: 2021 Macbook Pro M1Max
  • macOS version: Sequoia 15.6
  • BetterTouchTool version: 5.570
I changed the model name from gpt-4.1 to gpt-5, but then I got an error and it stopped working. When I checked the logs, I found the following error message.
    error =     {
        code = "missing_required_parameter";
        message = "Missing required parameter: 'messages[0].role'.";
        param = "messages[0].role";
        type = "invalid_request_error";
I’m guessing the API specs might have changed, but I’d be really happy if BTT could use the new model!
Thank you!
I remember (or am I hallucinating?) that Andreas mentioned that exact model names should be used. So maybe test with any of these - https://platform.openai.com/docs/guides/latest-model#model-name-reference ?
It seems to work ok here (apart from that gpt-5 with default settings is very slow for me)
Are you using this API url? https://api.openai.com/v1/chat/completions
Thank you for the information!
I checked out the links you shared and tried using some of the newer model names, like gpt-5 and gpt-5-mini, but unfortunately, I still got the same missing_required_parameter error.
Just to double-check, I even tried putting in a model name that doesn’t exist, like gpt-4.2. In that case, I got a different error saying “The model does not exist.”
So it looks like the problem isn’t with the model name itself.
Up until now, I’d been leaving the "URL To Call:" field blank, and it was working just fine. When I set the "URL To Call:" to the chat/completions URL, it worked as expected. And just as you mentioned, the response from GPT-5 was indeed slow.
Thanks a lot.
Ah interesting, I'll check why it doesn't work with blank url anymore.
Also next version will allow to set additional API parameters. The slowness is caused by the default gpt-5 settings that always put the model in "thinking" mode, which takes a long time.
However this week I'll also finally release my h@llo.ai labeled AI stuff into BTT, with that release these legacy actions will mostly become obsolete (but they will continue to be supported).
In 5.575 you can now specify extra api parameters. When entering these parameters gpt-5 should become faster:
{"reasoning_effort": "low", "verbosity": "low"}
Awesome! I tried it right away. Responses are faster so it feels much smoother. Being able to adjust the reasoning_effort for each trigger is really handy. Thanks a lot.
