Transform & Replace Selection With ChatGPT not working
Transform & Replace Selection With ChatGPT action does nothing when using 4o-mini.
What kind of window is this? Does it allow editing text?
Is the transformation not working in this sort of window or not at all?
This way Raycast Notes window that allows to edit text.
It's not working in any sort of window or application.
Here is another video trying the same in Text Editor
do you have a firewall enabled? If you want you can send the logs from this folder to me (andreas@folivora.ai), they should contain some details about potential errors:
~/Library/Application Support/BetterTouchTool/Logs (go there via Finder -> Go -> Go to Folder)
Just emailed you the latest log.
Thanks for looking into it.
Ah, connection looks good. So no firewall etc. issue.
Could you maybe copy & paste the whole configured trigger here that you use to execute the transform & replace? (or right-click => export to file and attach the file)
Sure, here you go
exported_triggers.bttpreset (2.2 KB)
