Trackpad Sensitivity
All I want to do is change the sensitivity of 1-finger tap-to-click. The default Apple System Preferences setting does not work for me at all, and the trackpad remains extremely over-sensitive even on the Firm setting.
Settings in BTT's FORCE Touchpad don't seem to be changing anything, and neither does anything in TipTaps. But perhaps these settings are for something else. Taps doesn't seem to have a 1-finger setting at all.
Advice?
I’m also looking for this, either in BTT or using some other application or hidden MacOS command.
The built-in slider is ridiculous and makes zero difference. I don’t want a tap to be registered unless I tap hard enough to make an audible sound, and that slider doesn’t even come near (in fact, I don’t notice any difference at all between the min and max settings).
