Trackpad right click triggering Normal Mouse trigger
System rebooted.
Latest Alpha installed (4.644)
I have only 'normal mouse' triggers on For All Apps.
Right click is rebound to apple+[ to go back.
When BTT is open the trackpad 2 finger secondary click also triggers this behaviour.
MacBook Trackpad, Evoluent Vertical Mouse 4
  • Type of Mac: M3 Pro
  • macOS version: 14.5
  • BetterTouchTool version: 4.6.44
that is expected behavior, for these standard trackpad functions (left,right click& scroll) the trackpad açts as a normal mouse.
If you want to prevent that you can use the advanced trigger conditions like this:
That might be the fastest and most useful reply I've ever got from any software I've ever paid for. Problem resolved. Thanks @Andreas_Hegenberg !
Hi @Andreas_Hegenberg ,
I've been using fingers_touching_trackpad == 0 for a few days and found that sometimes (2-3 times a day, possibly more common after coming back to the laptop and unlocking) a touchpad right click is still intercepted as a normal-mouse right click. The second attempt always works.
Do you have any advice, please?
Thank you.
