Im using BTT 3.621 (1770) and Monterey 12.0.1.
Setting does not seems to work since Monterey update.
Im using old Magic Trackpad .
Tried to restart, but no luck so far.
I'm having the same problem did you find a solution yet?
Are you both using one of the old Magic Trackpads? (It seems to work fine on my Magic Trackpad 2 & 3).
Possibly Apple has removed the upside down flag in the old driver.
