Trackpad Long and Short Swipe
I would like to have, for example, a short swipe left to perform one action and a long swipe left to perform another action. Is this possible?
For context, I use BTT in combination with Yabai for window management, and being able to do this would be convenient as it would reduce the degree to which you have to rely on using modifiers. As an example, if long and short swipes were supported, I could set a long swipe down to run a terminal command to minimise the focused window, and a short swipe down to warp the window south. As far as I know this isn't currently supported with BTT.
