I have BTT installed on my Mac. It works just fine, but for a while now, I've noticed that my trackpad gesture, which I set up since I purchased BTT, doesn't work after I boot my Mac. I have to quit BTT completely (a "Restart BTT" from the menu won't work), to make it work again.
This is so weird, and of course, most of the time, while relaunching it, it crashes my StreamDeck software as well, so I have to relaunch this one too (that’s a recurring bug, btw). Every morning, I have to do that to get my workflow running, which is pretty annoying, obviously. ![]()
It used to work before, and since I installed the fresh OS, actually. So, it might be related to a specific BTT version, maybe. However, the issue persists regardless of the new versions I’ve installed over time, including the latest.
- Type of Mac: iMac 5K 2019 - 3.6 GHz 8-Core Intel Core i9 - 128 GB RAM
- macOS version: Sonoma 14.8
- BetterTouchTool version: 6.017
EDIT:
I’ve just tried to reset the permissions using the Terminal:
tccutil reset All com.hegenberg.BetterTouchTool
(which kinda froze the OS afterwards (very unstable/unresponsive))
But after rebooting and giving the permissions again, it didn’t work. I still had to quit and restart BTT manually.
