Often I will open my laptop and the trackpad will not be able to click on anything. The haptic click doesn't fire no matter how hard I push and tapping doesn't trigger a click.
When I encounter this I look for the BTT process by pulling up a terminal window via the keyboard and ps -ax | grep Better
When I kill -9 {BTT_PROCESS_NUMBER}
the issue is resolved so I'm reasonably sure it is BTT. Upon restarting BTT the issue is gone for a while.
I will attempt to get clearer reproduction steps to trigger it consistently.
Affected input device (e.g. MacBook Trackpad, Magic Mouse/Trackpad, Touch Bar, etc.): MacBook Trackpad
- Type of Mac: M2 MacBook Pro 14-inch 2023
- macOS version: 14.2.1 (23C71)
- BetterTouchTool version: 4.369
