trackpad click always terminates loop
an earlier version of this mouse jiggler used a click on the trackpad to terminate the loop. This was getting really annoying so now i’m trying to make it terminate on esc instead. For some reason though, even after changing the rule, deleting it, re-importing it, it still terminates on a trackpad click.
  • Type of Mac: m1 macbook pro
  • macOS version: 15.71
  • BetterTouchTool version: 5.670
it seems to work as intended here. Maybe you have some additional trigger set up in your trackpad or normal mouse triggers that cancels the loop?
i’ve disabled everything else, still reacts to the trackpad click
in your video you are only looking at the keyboard shortcuts section, but if it’s a trackpad gesture or mouse click that cancels the loop it might be in a different trigger section
You’re right! i had these at the bottom. Not sure why this would interfere though? Thank you!
