I wonder, if I can use a
- 1 finger double tap as a trigger?
- 1 finger double tap & hold? (1x tap fast + 1x tap+hold)
- 1 finger tripple tap as a trigger?
And if yes, can they be assigned to left/ middle/ right/ up/ down areas?
Yes, I hard-core second this request!!! Looks like there's been a few posts/requests for this feature in the past, as well. Would love to make it happen!
@Andreas_Hegenberg - is there a way to do this by incorporating "Advanced Trigger Conditions"?
As far as I know, you can use the 1 finger tap gestures and select “double tap required” in the settings.
so cool! thanks for pointing this out!
Hoping there’s a way to create more variations of the 1 finger tap like OP mentioned ![]()
I added single finger tap and single finger double tap gestures in v4.613 alpha
Make sure to have tap to click disabled in system settings => trackpad if you plan to use these.
@Andreas_Hegenberg The new toolbar is cool ![]()
I tried out the new 1 finger gestures. Double tap works well. Single tap not at all.
Should BTT wait a certain (default) time after the single tap gesture to recognize if a second tap follows? Or how does that work?
yes, it waits a moment before triggering . The mouse cursor must not move during the touch. I’ll have a look!
Hi. is there a way to adjust this waiting time? I want BBT to not recognise slow double taps to avoid accidental touches.
