When I program my menu & screen buttons on the Siri Remote to previous/next playback actions, all it does is change the entire track. Is there a way to have it seeking within the track ie. forward/rewind the track by 5 or 10 sec (like in sirimote) instead of change the track completely?
If not is that a request the Developer will consider. I think it would be cool to rewind/forward a pre-set time frame when watching netflix, youtube etc.
Siri Remote
- Type of Mac: MacBook Pro Retina 13 (2015)
- macOS version: 10.13.6
- BetterTouchTool version: 2.634
