Touchpad sensitivity with 2 fingers TipTap
Hello
I'm Trying to Assign 2 Finger TipTap Right to Safari action CMD+Click (open link in new tab)
First I made this this settings:
They worked, but touchpad sensitivity was very bad, I had to use the power. Before that I used multitouch app and any soft right finger touch worked.
Then I tried this one:
It doesn't work.
Then I switched back to first setup and it doesn't work also. Nothing working now.
Wha's I'm doing wrong?
Thanks
I deleted and created CMD+Click trigge again and now it works again.
But the problem with the sensitivity is still persist. And overall the function seems unstable.
maybe It's not about sensitivity. it is also about how long I tap with right finger. I think when I hold right finger little longer on touchpad it doesn't work.
Only 50% of my TipTaps work correctly. With another software about 99% works.
I reallly need to find the solution
yes the tap sequence of the tip tap needs to be relatively fast, the right finger can not rest on the trackpad before the second tap happens. Unfortunately this can not be adjusted. For me it works 100%, but I see that it can take a bit time to get used to - I have been using that gesture for 15 years now :sweat_smile:.
I believe it is a personal and habit
I've been using it for 10 years, but through other app (Multitouch)
That would be great is it fixed or at least if BTT have some options to adjust sensivity
A screenshot from Multitouch settings:
it's TipTap works like a charm and have extra settings.
