Touchpad acceleration is slow
Even though I have increased the touchpad speed to the highest level in BTT, its speed remains slow. How can I speed it up even more?
unfortunately BTT can not do that (on modern macOS versions) :frowning:
The best app I know in this category is CursorSense. The fourth most important app on my mac ... after BTT, of course :wink:
https://plentycom.jp/en/cursorsense/
unfortunately I think on macOS Sequoia Apple disabled the API CursorSense was using... so enjoy while it lasts :slight_smile:
Really? Mm, a good reason not to update.
Couldn't you find a way to do that? Would be great!
And wasn't there once a terminal command to accomplish more or less the same thing?
yes first it worked with a terminal command, Apple killed that at some point. Then BTT also had this included once. Then Apple killed the API. Cursor sense was using a more low level approach - I was also looking into that as well, but now it's probably not worth it anymore as Apple has locked it down too ;-(
Not sure why they don't want us to change that stuff.
Apple also does not want fn to be used as a modifier (for whatever reason). Nevertheless, it works very well with BTT. Little things like that have never stopped you before. :wink: If you want, you “ll find a way”. I have full confidence in you. :slightly_smiling_face:
:wink: I'll keep looking, unfortunately this stuff gets harder with every macOS version.
They work harder, you work smarter. :wink:
Seriously, this trackpad is too slow for many. Maybe Apple has finally understood this and offers a higher speed as standard with Sequoia. Do you happen to know if that's the case?
If not, you are the last hope of all Mac users. :slightly_smiling_face:
no the maximum allowed speed hasn't changed ;-(
Grrrrrr! Completely incomprehensible.
