Touchbar Synced Lyric
I don't think it is compatible with those apps. None of them support Applescript, meaning I cannot ask them for music information it's playing. Only Spotify and Apple music are supported.
两个软件和这个程序并不兼容,主要是因为它们都不支持Applescript, 所以我没有办法获取正在播放的音乐信息。目前只有Spotify 和Apple Music提供支持。
My config looks like this, and yes I am using the app downloaded from Spotify Mac Download
Looks like there are some compatibility issues with python 3.10. I will take a deeper look
It has been updated to 0.6.9 and it should work with python 3.10. You can run this command to upgrade the package pip3 install touchbar_lyric --upgrad.
I confirm it works after the update! Thank you very much!
can anyone tell me how to do that correctly?
:smiling_face_with_tear::smiling_face_with_tear::smiling_face_with_tear::smiling_face_with_tear::smiling_face_with_tear:
You can find the correct python path by running which python. It should print something like /usr/bin/python3
Use this to update the config value so it ends up like this /usr/bin/python3 -m touchbar_lyric --app Spotify
There are 3 spaces in that value
Can anyone help me with this installation?? thanks
I dont know but i cant make it work. I am getting the following error;
Any help would be much appreciated.
Also when i do which python3, my python path is: /Library/Frameworks/Python.framework/Versions/3.11/bin/python3
/bin/bash: line 0: [: missing `]'
/bin/bash: line 2: BTTWidgetName: command not found
/bin/bash: line 3: BTTTriggerType: command not found
/bin/bash: line 4: BTTTriggerTypeDescription: command not found
/bin/bash: line 5: BTTTriggerClass: command not found
/bin/bash: line 6: BTTPredefinedActionType: command not found
/bin/bash: line 7: BTTPredefinedActionName: command not found
/bin/bash: line 8: BTTShellScriptWidgetGestureConfig: command not found
/bin/bash: line 9: BTTEnabled2: command not found
/bin/bash: line 10: BTTRepeatDelay: command not found
/bin/bash: line 11: BTTUUID: command not found
/bin/bash: line 12: BTTNotesInsteadOfDescription: command not found
/bin/bash: line 13: BTTEnabled: command not found
/bin/bash: line 14: BTTModifierMode: command not found
/bin/bash: line 15: BTTOrder: command not found
/bin/bash: line 16: BTTDisplayOrder: command not found
/bin/bash: line 17: BTTMergeIntoTouchBarGroups: command not found
/bin/bash: line 18: BTTTriggerConfig: command not found
/bin/bash: line 19: BTTTouchBarFreeSpaceAfterButton: command not found
/bin/bash: line 20: BTTTouchBarOnlyShowIcon: command not found
/bin/bash: line 21: BTTTouchBarButtonColor: command not found
/bin/bash: line 22: BTTTouchBarApplyCornerRadiusTo: command not found
/bin/bash: line 23: BTTTouchBarItemPlacement: command not found
/bin/bash: line 24: BTTTouchBarAppleScriptStringRunOnInit: command not found
/bin/bash: line 25: BTTTouchBarAlwaysShowButton: command not found
/bin/bash: line 26: BTTTouchBarFontColorAlternate: command not found
/bin/bash: line 27: BTTScriptType: command not found
/bin/bash: line 28: BTTTouchBarButtonWidth: command not found
/bin/bash: line 29: BTTTouchBarScriptUpdateInterval: command not found
/bin/bash: line 30: BTTTouchBarItemIconHeight: command not found
/bin/bash: line 31: BTTTouchBarButtonUseFixedWidth: command not found
/bin/bash: line 32: BTTTouchBarButtonTextAlignment: command not found
/bin/bash: line 33: BTTTouchBarAlternateBackgroundColor: command not found
/bin/bash: line 34: BTTTBWidgetWidth: command not found
/bin/bash: line 35: BTTTouchBarItemIconWidth: command not found
/bin/bash: line 36: BTTTouchBarShellScriptString: command not found
/bin/bash: line 37: BTTTouchBarIconTextOffset: command not found
/bin/bash: line 38: BTTTouchBarButtonFontSize: command not found
/bin/bash: line 39: BTTTouchBarFontColor: command not found
/bin/bash: line 40: BTTTouchBarButtonName: command not found
/bin/bash: line 41: BTTTouchBarButtonCornerRadius: command not found
/bin/bash: line 42: BTTTouchBarItemPadding: command not found
/bin/bash: -c: line 44: syntax error near unexpected token `}'
/bin/bash: -c: line 44: ` }'
