TouchBar not working on mission control state
Steps to reproduce
Start BTT TouchBar
Start mission control (3 or 4 fingers swipe up on touchpad)
Buttons on TouchBar not responding
Affected input device (e.g. MacBook Trackpad, Magic Mouse/Trackpad, Touch Bar, etc.): TouchBar
Type of Mac: Macbook Pro 13-Inch 2018
macOS version: 10.15.3 (19D76)
BetterTouchTool version: 3.281
Unfortunately that's a system limitation, macOS disables all custom Touch Bars when Mission Control is active.
I have this problem too. Thanks for your reply. Don't you know if there is some way to disable this "protection"? Some hidden system flag, or something similar...
Or – at least – some way to disable BTT Touch Bar when Mission Control is on? (when it's not usable anyway)
unfortunately none of that is possible as far as I know.
BTT
March 11, 2021, 1:49pm
#5
@Tanin_Thanasopon @tomasbedrich
Check out my thread here about this topic where I may of found a workaround that can be introduced in the future: I may have discovered a way to get the Touch Bar to work when using Mission Control
